Old 12-08-2010, 09:42 AM   #113 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I found some info on my 1.6HDi engine's thermostat:
Thermostat starts to open at 83C and fully open at 97c
So, if my normal hypermiling temperature rarely exceeds 78°C, then my radiator should be luke warm (I'll have to remember to check that). Unless the temp sensor and/or Scan Gauge II are slightly off. A t-stat that starts to open around 90°C may not be available, since this is specifically for this engine, and comes in a big plastic housing, along with a temperature sensor and a bunch of hoses. Expensive overkill, if you ask me.
