Thread: Diesels and EGR
Old 12-08-2010, 10:56 AM   #11 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Thanks guys for all your responses. I am trying to make the best informed decision and I appreciate all your viewpoints. Nacht, environmental concerns are one of my considerations. (most days I do not start my car and commute by bicycle even down to 20 below zero). On the other hand, I live in a sparsely populated area surrounded by three coal fired power plants. My NOx contribution would be minimal from a 50 mpg vehicle that I barely drive.
VWs are prone to manifold clogging ($300 repair- the manifold must be removed or replaced), cracked EGR tubes (I'm on my second set- $300 in parts alone), clogged EGR coolers, and sticking/clogged EGR valves making the vehicle run poorly.
My original post was to ask how it affects primarily highway mpg? Keep those comments on efficiency coming!
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
