Originally Posted by jamesqf
How does the weight of e.g. fancy chromed metal valve caps vs the standard plastic affect the valve stem?
Why should they, if you've already got a built-in TPS? The point is, the sensors and transmitters are all pretty much the same, and dirt cheap - or maybe I should say silicon cheap, 'cause they're integrated circuits, and if you can build one, the incremental cost for turning out millions isn't much. So if someone is quoting you hundreds of dollars for replacement, either they're talking labor, or pulling the old "charge way over the market for OEM parts" scam.
Why? I prefer not to have my life restricted by the least-common-denominator limitations of the average idiot.
Well, I am sure that the weight of small chrome caps are not significant. But, go ahead, have your valve stems tear off. I have seen it before, but I know that there will be someone who will argue...
As for the cheap as silicone, sure you can get aftermarket. That is what autozone is. some cars are considerably cheaper, some aren't. I dont think autozone is OEM, but then again you have many options out there like CQ, NAPA, Checker, etc...
WHY? well, the average consumer wouldnt have inflated the tires to 51psi (turning on the light in the first place) and the average consumer wouldnt have coroplast hanging off their car and....It is absolutely fair to pay $150 for the install of the sensor that I was showing. Can I find a brand with cheaper sensors, give me a second...
