Thread: Diesels and EGR
Old 12-09-2010, 11:43 AM   #18 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Big Dave View Post
It varies from engine to engine.
Doesn't seem to help VW TDI engines.
It helps Ford 6.0 and 6.4 engines a lot as it does the Cummins 24 valve.
Big Dave, If I am reading this correctly, EGR HELPS with mpg in some diesels but hurts the VW TDI? Can you add links to your sources please? Some folks claim EGR hurts mileage, some say no difference, and some say it helps diesel mpg.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
