Old 12-13-2010, 08:14 AM   #1 (permalink)
saand
Wiki Writer
bugler - '91 Mazda 626
90 day: 35.89 mpg (US)
Alternator disable switch by disabling the field
Hi All,
The next mod on my list is the alternator disable switch. I can easily turn off the output of the alternator just using a relay however there are advantages to just turning off the excitation field.
I attempted this by trying to isolate the field wire that goes into my alternator. So i cut a wire, ran the engine and no success, the voltage on the battery actually went up. So I was a bit confused then after a bit of research i realized this is likely a feedback wire which tells the alternator what voltage the battery is at so that the alternator can alter the excitation field to increase or decrease the charging rate.
I then reconnected this wire and cut another wire, but found the same issue, this may or maynot be the return wire for the voltage sensing.
The only wire left that i can see is the output wire, the positive that goes to the battery to charge it.
Other forum threads have suggested some cars have a dedicated field enable /disable signal however from what i can see so far mine may not have this.
So a question to anyone that knows about disabling the field of an alternator. Is there any way i can interrupt the field without actually opening up the alternator and isolating one of the excitation field brushes.
Thanks
