Old 12-13-2010, 07:14 AM   #1 (permalink)
Wiki Writer
bugler - '91 Mazda 626
90 day: 35.89 mpg (US)
Alternator disable switch by disabling the field
Hi All,
The next mod on my list is the alternator disable switch. I can easily turn off the output of the alternator just using a relay however there are advantages to just turning off the excitation field.
I attempted this by trying to isolate the field wire that goes into my alternator. So i cut a wire, ran the engine and no success, the voltage on the battery actually went up. So I was a bit confused then after a bit of research i realized this is likely a feedback wire which tells the alternator what voltage the battery is at so that the alternator can alter the excitation field to increase or decrease the charging rate.
I then reconnected this wire and cut another wire, but found the same issue, this may or maynot be the return wire for the voltage sensing.
The only wire left that i can see is the output wire, the positive that goes to the battery to charge it.
Other forum threads have suggested some cars have a dedicated field enable /disable signal however from what i can see so far mine may not have this.
So a question to anyone that knows about disabling the field of an alternator. Is there any way i can interrupt the field without actually opening up the alternator and isolating one of the excitation field brushes.
Thanks
Old 12-13-2010, 09:48 AM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
It is very possible that your alternator is self exciting, as is mine (only one thin wire, disconnecting which doesn't do anything). AXMonster started a great thread (Automatic alternator cut out/regen braking), where got down and dirty with his internal field alternator, but it appears that rewiring the diodes inside wasn't enough It's worth a read, though, and your alt might have a slightly better (= easier to hack) design.
The Following User Says Thank You to Piwoslaw For This Useful Post:
saand (12-13-2010)
kill switch 5th gen honda civic bestclimb DIY / How-to 30 02-03-2015 01:39 PM
Kill switch how-to bbjsw10 DIY / How-to 195 05-20-2014 01:27 PM
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
Another IMA defeat switch bikeracer Hybrids 1 02-01-2010 04:48 PM
Field Weakening Experiment for Speed Increase TomEV Fossil Fuel Free 12 04-10-2008 03:53 PM
