Originally Posted by Pholostan
To prove a mpg increase you'll have to break the laws of thermodynamics. Not gonna happen. The energy needed to make the hydrogen is far more than the energy you get from burning the hydrogen. Go figure...
I have to correct you on the above statement. You will not have to break that law or even come close doing it. As you should know that water broken down has energy, and lots more the gasoline. When you break down the atoms and and implode it you get a great I MEAN GREAT source of energy that you can use to run the car. And its not that hard, You can use the existing fuel line that runs to the injectors. Keep pressure at small load 30 PSI and 50 on full run. with a v8 350HP truck for example. For that to work to you will need to retard the timming to get the injectors to shoot in enough fuel
You have to also crack it even more then just electrifying the water if you want to realease the huge amount of stored energy...
