Thread: Hydrogen Engine
Old 12-13-2010, 10:20 AM   #15 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by tf4624 View Post
The can go 200mpg or more on gas alone if they wanted to. by the way.
You use 25% of the energy in gasoline to move you down the road so in order to make a 50mpg car get 200mpg you would need to use 100% of the energy in the fuel, as it is 75% of the energy is being turned in to heat, so you would end up with an engine that runs cold!
I've split water both in a jar and with what I believe was a Swiss built electrolyzer, it takes massive amounts of energy to split water and what you get out of it is not that great, hydrogen is also not a dense fuel, so it takes up alot of space and it just does not work.
If you have some new great idea that you think will work then you should go and make it a reality for your self, it will keep you out of trouble but you are going to have a hard time making breaking the laws of physics.
