Originally Posted by Ryland
You use 25% of the energy in gasoline to move you down the road so in order to make a 50mpg car get 200mpg you would need to use 100% of the energy in the fuel, as it is 75% of the energy is being turned in to heat, so you would end up with an engine that runs cold!
I've split water both in a jar and with what I believe was a Swiss built electrolyzer, it takes massive amounts of energy to split water and what you get out of it is not that great, hydrogen is also not a dense fuel, so it takes up alot of space and it just does not work.
If you have some new great idea that you think will work then you should go and make it a reality for your self, it will keep you out of trouble but you are going to have a hard time making breaking the laws of physics.
It is quite possible stop feeding into to the lies you are told or read about on hy_rog_n powered car. It does take great energy to split water but you need to understand Voltage and amperage and how to to make them work efficeintly to get what you want to split the Hyd_ _gen and water to make the fuel. you also to have to IMPLODE the atoms too. They hydrogen takes up space if you have no where for it to move or made on demand, which is what you need to do!.
