Thread: Hydrogen Engine
Old 12-13-2010, 06:58 PM   #23 (permalink)
tf4624
Eco of course
Cant create energy from nothing..that right BUT....
Originally Posted by Angmaar View Post
You can't just "create" energy from nothing. The more amps you are using from the alternator the more the engine has to work to generate the electricity. Also the electrolysis of water to hydrogen is only 50-80% efficient and most alternators peak at 60% efficiency.
Your absolutly right on that and im not doing anything like that. As there is potential energy in the water molecule that you must extract and you can do it while having higher efficientcy You would be looking at 300% increase of energy released from the water molecule. You need to think of other current flow. But like I said if you think one sided like this with amps..you won't get what you want unless you have an on demand system to control the heat issue
