Originally Posted by tf4624
Your absolutly right on that and im not doing anything like that. As there is potential energy in the water molecule that you must extract and you can do it while having higher efficientcy You would be looking at 300% increase of energy released from the water molecule. You need to think of other current flow. But like I said if you think one sided like this with amps..you won't get what you want unless you have an on demand system to control the heat issue
Cold fusion? 300% increase? That's not nearly enough energy, you are off by six or seven orders of magnitude.
