Old 12-14-2010, 09:35 AM   #8 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Winfield1990 View Post
I would worry more about tire weight for unsprung weight than LRR
Unsprung weight certainly is an issue.
there is alot more slip from having LRR and less traction while accelerating
Then you're giving it too much throttle, or the tyres are shot.
Even my lowly 109HP FWD car would spin its rather sporty Continental Sportcontact 3 tyres when I was too enthusiastic with throttle and clutch.
Surely it can spin its LRR too ...
and you have to slow down more on turns,
While hypermiling, one is often already going slower.
Of course the LRR tyres don't corner as well as a sportstyre, but the newer / better ones are perfectly driveable.
I often have other cars right up my tail on the exit ramp from the highway as I coast to bleed off speed. They tend to quickly fall behind once we get into the bends off the exit ramp - often a 90° to 180° turn - as I generally don't brake to turn in, while they do.
and your breaking and performance are sacraficed
Hypermiling means you're not exactly going for performance, so that doesn't really matter.
Braking with a good LRR tyre is OK, though obviously not as good as a sportstyre, and it really isn't expected to be as good anyway.
You can't expect sportstyre handling and braking from a LRR tyre - nor from a regular run-of-the-mill tyre either. But you pay for the better handling & braking as you wear them down a lot faster and use more fuel doing so.
Biggest question is what speeds do you normally coast through turns?....
"Normal" speed is irrelevant as you need to consider all aspects of every different turn.
In order to keep up the momentum, I tend to go faster through turns on LRR tyres than many people on whatever they are driving.
That includes the local Johnnys and cars with twice or more the HP.
