Originally Posted by roflwaffle
IIRC it was a Jackass minimal CD. Same install for a stage three as Gentoo, although it'll probably take a day or more to compile everything depending on what you need. Also, if this has windows on it already, you can try UNetBootin to install from within windows.
Thanks all...
The HDD had a corrupt Win98 OS on it before I started formatting and partitioning for whichever Linux variant was tried.
Puppy was too much for it and it barely budged after about an hour after making a request (not enough memory). Vector Linux -- can't download a decent version (bad checksums).
I may try DSL or trustix. Honestly, my noobness currently requires a GUI, which likely steals from the total power available. On my newer machines, I've used OpenSuse, and a variety of Fedora releases with ease.
One is a backup server for 2 laptops (primary household workstations). So far, old, doorstop PCs have been saved from the recylcler.
RH77
