the point is, as I describe in post 67, there is a way to minimize clutch wear. If you broke it in 40k, you were having too much "fun". You could wear out a set of brake pads in 10k miles if you tried also, it isn't the cars fault.
Automatics are not a "must", except for certain handicaps. And making excuses that you "must" have one is not eco.
