Thread: Hydrogen Engine
Old 12-15-2010, 07:54 PM   #70 (permalink)
IamIan
IamIan's Avatar
Originally Posted by tf4624 View Post
Its been done already, I've told you to look it up, but since you guys or some of forgot how to use the internet.
I suggest you read more carefully ... it seems you are misunderstanding what people are posting , and completely missing some things people are posting.
We have not forget how to use the internet ... we already knew the information you posted in your links ... none of those are anything new ... we already know many things about each of those including the limits each has , and how they work... which some us of, me included have already tried to explain to you.
4 of your examples were ICE hydrogen vehicles ... none of those examples you gave have ICEs operating at over ~40% efficiency.
I also already posted about the Honda Fuel Cell you linked to which maxes out at ~60% efficiency ... and the Ford fuel cell is not any better.
We already know the volumetric energy limits of hydrogen ... and we know the efficiency limits of these vehicles... and we know the energy used for aerodynamics, rolling resistance, etc.
Read what we are posting to you more carefully ... you seem to be missing allot.
The claim is more on a logical standpoint.. that being; there is more then one way of doing things as you know :-)
You can split water the same way of electrolysis but can also do it in another fashion while using the same principles. You just have to figure out how to go further then just the basics of Electrolysis. That is the point im makeing .. More then 1 way to skin a cat, if you will.
I already went through this as well... you seem to have forget my first post.
I already posted about the Electrolysis ... and alternative methods to allot split water to extract the hydrogen... go back and re-read more carefully.
If you want to delve / explore one of those options in more detail ... please by all means ... bring on the 'techy'.
Claim two would follow that we have cars and engines running off of hydrogen
We already know this ... that isn't the issue ... you should read more carefully.
We are all well aware of people running vehicles on hydrogen ... including getting over 12,000 MPG from hydrogen... as I posted.
However we know enough about these vehicles including the ones you posted links to ... to know how they work and what they can and can't do.
We do not just believe people without proof ... the opinions we have are based on proof and real data ... I have myself run experiments first hand ... as have several others on this forum ... If your opinion differs you need to provide at least equal quantity and quality of 'techy' , details, proof... so if you have 'techy' ... I still say ... bring it.
So far you have offered nothing to back up your claims ... back it up ... bring on the 'techy'.
Dont go putting words into someones mouth.
I didnt say you get "Balanced" energy out of it.. NEVER did i say BALANCED
Yes, I did make that point. and yes you can use hydrogen to run things in positive way, it doesn't need to be an = balance.
Water torch runs with it by doing the same.
You have misunderstood... and he isn't putting words in your mouth ... you did.
When he wrote about , 'positive energy balance' , he was referring to your claim of 300% efficiency.
Does this look familiar.
Yes for Example there is a fuel cell that runs 300 percent.
This is you claiming a 300% efficient fuel cell ... when the best examples posted ... are 60% efficient.... and I was the one who posted that much ... because you wouldn't / couldn't even give us that tiny bit of 'techy'.
If you have 'techy' that supports your claims ... like 300% efficiency ... bring it ... bring us the 'techy' ... there are allot of well educated , experienced, and informed people on this site ... we can help you to understand what is really happening ... what is really going on ... you can learn more than you know now.
So if you got the 'techy' ... bring it.
Originally Posted by euromodder View Post
He won't 'cause he obviously can't
I had hoped to at least to get some kind of elaborate 'techy'... come on ... wow us , with talk of energy band gaps, quantum spin, temporal flux, Dilithium crystals, Naquda , Tachyons, etc... I mean come on ... bad sci-fi has more 'techy'.
