Old 12-18-2010, 11:29 AM   #4131 (permalink)
sawickm
ReVolt Enthusiast
Originally Posted by MPaulHolmes View Post
The only reason I was using the dspic was because I wanted it to have CAN, so it can talk with the bms and charger while driving.
Hey Paul,
If you want to add “CANbus” to the Atmega ReVolt Cougar PCB than check this out: CAN-SPI Adapter
You should just be able to interface it into the “Cougar” Rev.C SPI port.
If that would work ??? “CANbus” could be added on-board for next version of the “Cougar” Rev.E ???
-Mark
