Old 12-24-2010, 02:39 PM   #4146 (permalink)
Weisheimer
Mark Weisheimer
Originally Posted by MPaulHolmes View Post
How does a hall effect throttle work? Like if You had one lead hooked up to the A/D input, and one lead hooked to ground, when you hit the throttle, does the wire connected to the A/D input vary from x to y (0 to 5v or whatever)?
Yes, that is what it does with the Curtis hall effect foot pedal.
I think that the Chennic one is the same.
Last edited by Weisheimer; 12-24-2010 at 02:41 PM.. Reason: change is to it...and chenic to chennic...
