Old 12-24-2010, 10:07 PM   #6 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
if you are doing highway driving a taller tire wheel combination will lower the rpms at cruise. That's the name of the game. dont go overboard. your looking to increase the diameter by 3-7%. Tirerack dot com can give you alot for specs on tires. Also remember that there is a wieght issue. (previuos posts) each puond over factory is 4 times when it is rolling. so there is more wear on the brakes etc. of course your driving easy.
And the higher psi is a less forgiving ride.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
fairdinkumfrankies (12-25-2010)
