Hi All,
I have recently modified my alternator to allow field disabling which stops the alternator producing electricity and reduces the load on the drive train slightly.
There are some alternators which have a signal feeding into the unit to disable the field. Mine unfortunately did not have this signal as it is fairly old. To perform the modification i opened up the alternator and interrupted the field circuit at the brushes.
For others interested i wrote up the method in the wiki, its located here
Alternator Disable Switch - EcoModder
I am not yet sure how effective this mod is for reducing fuel usage however the modification does allow manual turning on and off of the alternator charging.
