You need to adjust the throttle plate closed value. default is like 22 take it down to ~ 18 and see if it helps. the value is telling the SG that when the throttle is at XX value it is fully closed. I think my car is at 17 or so.
Your car may not cut off fuel when coating in gear, if so just put the value to 0.
