I tried the Compression tester thing already... Rented one from AutoZone, and couldn't get anything but a 0 reading on any of the cylinders, I thought I should get something- even if it wasn't what it should be, right?
Fuel System, I try that today- the pump does prime, but that doesn't mean it's "doing the job", so thanks!
Where is the injector, is it right there under the air cleaner bolt, it's above the throttles flap right, I'll clean the connectors too- signal may be distorted, "oily" from when she seized it...
Ignition Mod, seems to be working, and spark to all three plugs, tested that with all three hanging out while cranking.
Currently working on the timing cover, just to ensure the timins is on, and I'm not cranking in vain...
Thanks!
