Basjoos Wannabe
I kinda like ABS when driving on ice. Going down a steep hill in the ice one year with an ABS equipped minivan, I enjoyed watching how the van would get up to 15 mph, then it would pulse the appropriate brake to keep the van going straight.
Regardless of which is better, for many people who brake in an emergency, they freeze up which would be certain disater in a standard braking car, but with the ABS it might be ok.
I think the real cool one is traction control. Only drove one car with traction control, and when I got stuck trying to climb a steep dirt driveway, I just gave it gentle throttle til the car sorted how to climb the hill, which it eventually did.
From the wiki article:
A 2003 Australian study by Monash University Accident Research Centre found that ABS:[1]- Reduced the risk of multiple vehicle crashes by 18 percent,
- Reduced the risk of run-off-road crashes by 35 percent.
On high-traction surfaces such as bitumen, or concrete, many (though not all) ABS-equipped cars are able to attain braking distances better (i.e. shorter) than those that would be easily possible without the benefit of ABS. In real world conditions even an alert, skilled driver without ABS would find it difficult, even through the use of techniques like threshold braking, to match or improve on the performance of a typical driver with a modern ABS-equipped vehicle. ABS reduces chances of crashing, and/or the severity of impact. The recommended technique for non-expert drivers in an ABS-equipped car, in a typical full-braking emergency, is to press the brake pedal as firmly as possible and, where appropriate, to steer around obstructions. In such situations, ABS will significantly reduce the chances of a skid and subsequent loss of control.
In gravel, sand and deep snow, ABS tends to increase braking distances. On these surfaces, locked wheels dig in and stop the vehicle more quickly. ABS prevents this from occurring. Some ABS calibrations reduce this problem by slowing the cycling time, thus letting the wheels repeatedly briefly lock and unlock. Some vehicle manufacturers provide an "off-road" button to turn ABS function off. The primary benefit of ABS on such surfaces is to increase the ability of the driver to maintain control of the car rather than go into a skid, though loss of control remains more likely on soft surfaces like gravel or slippery surfaces like snow or ice. On a very slippery surface such as sheet ice or gravel, it is possible to lock multiple wheels at once, and this can defeat ABS (which relies on comparing all four wheels, and detecting individual wheels skidding). Availability of ABS relieves most drivers from learning threshold braking.
A June 1999 National Highway Traffic Safety Administration (NHTSA) study found that ABS increased stopping distances on loose gravel by an average of 22 percent.[12]
According to the NHTSA,"ABS works with your regular braking system by automatically pumping them. In vehicles not equipped with ABS, the driver has to manually pump the brakes to prevent wheel lockup. In vehicles equipped with ABS, your foot should remain firmly planted on the brake pedal, while ABS pumps the brakes for you so you can concentrate on steering to safety."
When activated, some earlier ABS systems caused the brake pedal to pulse noticeably. As most drivers rarely or never brake hard enough to cause brake lock-up, and a significant number rarely bother to read the car's manual,[citation needed] this may not be discovered until an emergency. When drivers do encounter an emergency that causes them to brake hard, and thus encounter this pulsing for the first time, many are believed to reduce pedal pressure, and thus lengthen braking distances, contributing to a higher level of accidents than the superior emergency stopping capabilities of ABS would otherwise promise. Some manufacturers have therefore implemented a brake assist system that determines that the driver is attempting a "panic stop" (by detecting that the brake pedal was depressed very fast, unlike a normal stop where the pedal pressure would usually be gradually increased, Some systems additionally monitor the rate at the accelerator was released)[citation needed] and the system automatically increases braking force where not enough pressure is applied. Hard or panic braking on bumpy surfaces, because of the bumps causing the speed of the wheel(s) to become erratic may also trigger the ABS. Nevertheless, ABS significantly improves safety and control for drivers in most on-road situations.
Anti-lock brakes are the subject of some experiments centred around risk compensation theory, which asserts that drivers adapt to the safety benefit of ABS by driving more aggressively. In a Munich study, half a fleet of taxicabs was equipped with anti-lock brakes, while the other half had conventional brake systems. The crash rate was substantially the same for both types of cab, and Wilde concludes this was due to drivers of ABS-equipped cabs taking more risks, assuming that ABS would take care of them, while the non-ABS drivers drove more carefully since ABS would not be there to help in case of a dangerous situation.[13] A similar study was carried out in Oslo, with similar results.[citation needed]
 RIP Maxima 1997-2012
Originally Posted by jamesqf
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
