Either is posible - Your on the right track - ckeck timming first - Sorry about the pulley - We all go through that - You might be able to just pop the stuck cover - Little gental persuasion ( you know screwdriver and rubber hammer gently - it will give ). See if the cams turning at all. Maybe lost teeth on belt ? 4 Months should realistically not have stuck them unless it went through a flood or some s@#. Let us know how it goes ?
