Just a thought from an old wheel alignment tech--if you are thinking about trying 0-toe on an older vehicle you will have to make sure that none of your front end components have any play in them. This includes suspension bushings as well as steering linkage. Toe in applies some force to your suspension to keep any slop tight in normal driving. 0-toe is not self aligning and any sloppiness will exaggerate any tendency to wander.
