Old 12-29-2010, 11:02 AM   #129 (permalink)
jackbauer
jackbauer's Avatar
I've only breifly looked at this project but is that a permanent magnet generator? If so you could just rectify the output and reduce the engine speed to regulate charge.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
