Old 12-21-2010, 03:20 PM   #121 (permalink)
Building the future! :-)
Like others, I believe in your work Ben, best of luck to you (also I made my office staff all vote too) lol
Old 12-21-2010, 04:14 PM   #122 (permalink)
90 day: 51.82 mpg (US)
We should get Craftsman sponsoring an EM contest.
I wonder how much busier Instructables is than EM...
Old 12-21-2010, 04:19 PM   #123 (permalink)
Wow ... answered my own question: WAY busier than EM!
Instructables.com Site Info
Old 12-22-2010, 12:01 AM   #124 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Of all the crazy, dangerous things I do, ( and I didn't even blow myself up with my homebuilt Propane/Electric Hybrid)
And I go and do this.
Bad kitchen knife, bad!
Looks like I won't be doing any more work on they hybrid for a few days...
On the up-side, I think it also gets me out of diaper-duty.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 12-22-2010, 05:07 AM   #125 (permalink)
PaulH
MPaulHolmes's Avatar
No chance. That big finger pad thing is the ideal baby wipe. haha
kits and boards
Old 12-29-2010, 10:07 AM   #126 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Ack! I haven't been doing much work on this project since trying to chop my finger off. (Totally unrelated, I assure you....)
Also, I have had some trouble with the charger. No, it's not because of running it from a generator.
I was having some trouble with the charger this summer. The charger would come on and start charging, but quickly taper down it's power. I figured that wouldn't be a problem for the hybrid setup because the issue appeared to be a mis-recognition of the "fullness" of the battery pack. With the batteries under load, the voltage drops, and the charger kicks in to full.
I tried replacing a bad resistor on the charger's circuit board. After that, it didn't work at all! Well, the charger still came on, the green light glows, and the fan blows, but no amperage out!
The manufacturer is no longer in business, so no tech support there. I did e-mail somebody that I know of who has one of the same chargers. He checked the color code on his resistor and let me know (I didn't know the exact value of resistor - ash is not a color) and found out that the one I had put in was wrong.
I replaced it with the correct resistor value. Still not working! Grr.
I think the best way to do a serial hybrid would be with a built, dedicated, charger designed to run specifically near the max continuous output of the generator. Maybe I could take my charger apart and use it as parts to build such a thing?
On the up side, the project has just become a finalist in the Craftsman Tools Contest.
To be fair though, they do 30 finalists, but only one project will earn $5000 in tools.
That, and my project is up against a trebuchet, a made-from-scratch old-timey bicycle, and a TARDIS!
My YouTube Videos
Old 12-29-2010, 10:13 AM   #127 (permalink)
A Tardis??? Sorry Brian, but you gotta admit, a Tardis?? :-)
Old 12-29-2010, 10:37 AM   #128 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Thankfully, the TARDIS is only a bookcase. (Well, I suppose that BOOKS are bigger on the inside than the outside.)
I really like the old-timey bicycle too.
My YouTube Videos
Old 12-29-2010, 11:02 AM   #129 (permalink)
jackbauer's Avatar
I've only breifly looked at this project but is that a permanent magnet generator? If so you could just rectify the output and reduce the engine speed to regulate charge.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 12-29-2010, 11:15 AM   #130 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Jack, you make it all sound so simple!
Yes, it's an outrunner permanent magnet generator.
If you can give me details of how to control amperage and voltage, I would love to hear them. I have never built any kind of a battery charger before, but I think I am slowing working up the courage to do it.
I would prefer not to modify the generator itself. I finally got the thing running right. It's a nice little generator that could power my home in case of a blackout. Also, since this is all sort of experimental, I don't know that I won't go with a different/bigger generator in the future.
If I can route the AC 110V output of the generator to an external box that would have the rectifier and associated gear in it, that would be great. I have no idea how to control the speed on the thing without really messing with it.
Ideally, I would also like to have a system that would be easy to modify between 72V and 108V. I am still tempted to try to cram 3 more batteries under the hood. I think it's possible, but it will be really tight, and I have to move everything else around under there. Higher voltage on EVs has SO many advantages. However, I would need a higher voltage charger.
My YouTube Videos
"The Volt" May BE SCRAPPED!- NEVER BUILT!! Jammer Hybrids 460 08-22-2013 07:08 PM
DIY hybrid (detailed noodling of crankshaft-mated electric assist method) NiHaoMike Hybrids 16 03-03-2012 05:41 PM
Volt may become a parallel hybrid RobertSmalls Hybrids 43 10-10-2010 07:14 PM
--- 48 volt golf cart motor --- for diy hybrid possible? basslover911 Hybrids 19 07-06-2010 06:46 AM
News: GM planning dedicated high efficiency hybrid (in addition to the Volt) MetroMPG Hybrids 17 07-16-2009 10:20 PM
