Old 12-29-2010, 05:36 PM   #133 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
You can see some photos of the charger at:
MobileMe Gallery
The generator does increase speed to power larger loads.
The generator has a stepper motor with a linkage to the throttle. The control circuitry runs the stepper motor to control the throttle, and increases throttle when there is a higher amperage demand. I wonder if the generator would work properly with the linkage between the throttle and stepper disconnected. I could instead have some sort of a manual throttle linkage in place. I don't know if the generator would sense this as some sort of error and shut down, or if it would allow me to do it.
If I could remove the linkage easily, (so it could be hooked back up without any permanent damage) that might be interesting to try.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
