Old 12-30-2010, 07:14 PM   #41 (permalink)
92Metro
Here's where I'm at...
Got the valve cover off, and all looks good to me when cranking it... Oil is flowing, cam is turning, all the lobs are good- lifters are going up and down as they should, I don't know? If the lifters are being pushed up and down, that valves are moving right, wish I could see from the plug hole. Up in there, to see if things are from sure moving as they should...
The one thing that I still can't get off of. When cranking it over the throttle body is "dry" on the time, if I cut the fuel line- to get it pulled off all the way. And catch the fuel, how much we talking about, that should come out?
Back to the throttle body, like I said its' "always dry" should I see something here right? I sprays from here into the intake and gets distributed from that point to the cylinders... I just not seeing any fuel- I swear I'm just cranking air, no- or not enough fuel to do anything?
Going to try taking it off, maybe it's plugged up- or not good?
Any suggestions?
