Thanks for the responses. I actually have a 150 Watt Kats pad on order from the US so I want to figure out a way to make it work. I guess I should have looked at the pan closer before I ordered it (me bad), but with the belly pan on, it's hard to see. I don't want to remove it until I get the pad. The picture is one I took before installing the belly pan and I remembered it after I had placed the order. The Kats pad is 4x5 so I need that large of an area, but I think the JB Weld might work. The left side of the pan is not as wavy. The Kats pad was 1/3 the price of the Wolverine one and higher wattage so I thought is was worth a try. Tygen1, your results are encouraging, I hope this helps me too.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
