I used plexi glass. 3/16" was $.035 per sq in. 1/8" lexan was .05 per sq in. $75 was plenty expensive.
The angles are about where they will be. If it does not work I might mod it, but for now it is set.
Well i got everything but the bottom and the areas that touch the car done with one coat of fiberglass. About 1/2 of it has a second (in some places 3) coats on it and should be ready for priming tonight after my birthday dinner out
I might even start on the car transition area tonight.
