Old 01-05-2011, 05:28 AM   #7 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by meelis11 View Post
Is this heat pad alone enough to warm up engine (warm coolant so engine does not waste fuel in first minutes to warm-up) or is it for oil warming and lubrication?
The engine will not get HOT, but it will be warm. Cold coolant doesn't directly effect wear, but cold oil does. (Cold coolant may effect ignition, but only in diesels.) The warm-up times will be shorter, since the oil will transfer some of its heat to the block and coolant once it starts flowing.
How many gas-engine users are using engine heaters?
The ones I know of are Tygen1 and MetroMPG. Both use them together with a coolant heater, but a lone heating pad will also do its job, as long as it is plugged in for 4-6h, instead of the coolant heater's 1-2h.
