Originally Posted by MetroMPG
ChristophR - can you walk me through how you set up Google Reader to subscribe to the forum? Is it the entire forum, or just selected subforums?
It's the entire forum, I just followed the link that was provided for RSS well over a year ago on here... erm, so my exact recollection is sketchy -- I'll dig in and figure it out if you need it further.
(Found it... used the RSS link in the URL box in the browser, and I used the entire forum, not a subforum RSS. I just added it in the appropriate field in Google Reader, and it subscribed me to the feed thereafter.)
http://ecomodder.com/forum/external.php?type=RSS2
However, I don't think you'll need that per se:
I did check back and there was a point in time where the RSS feed did work, and then did not, so I'll post the summaries with times, and the links:
Working:
Aerow-E ( my new car design )
Forum: Aerodynamics Posted By: jason1973tl Post Time: 01-03-2011 at 10:12 AM
http://ecomodder.com/forum/showthrea...=Google+Reader
Nonworking from this date onward:
the flywheel test (switched to 2 kg / 4.4 lbs lighter flywheel)
Forum: EcoModding Central Posted By: pounsfos Post Time: 12-17-2010 at 08:47 AM
The post date WAS after the date of the working one in the summary... so there's a date-time offset somehow muddled up with the server or software... somewhere. When I reviewed over the others, they're similar to this, all set much earlier in date than they really are. Times are fixed now for the past day it seems, but despite that, those posts will not come up as they ought to be.
I'm not sure at first look if the posts are adjusted to my timezone, or not, but mine is Easter Standard Time, if you need to make adjustments to compare to server time.
