Old 01-05-2011, 06:10 PM   #8 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
The ScanGuage II is pretty accurate on my TDI although if I mash the pedal to the floor, it wil go to 9999 for a few seconds and I know that's not right! Arragonis, are you considering E(off) coasting out of curiosity or in the name of science? Our diesels are so much more efficient at idle than a gasser (petrol) that I haven't felt that it was worth it. Depending on my coasting speed (engine on, in neutral) my ScanGuage reads 300-450 miles per gallon Or more! and that's not too bad. I was worried about shutting off the oil supply to a hot turbo, wear and tear from bump starting so often, and on my car, disabled airbags while the key is off. I am sure it can be done safely under the right conditions. I will be following your progress.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
