Old 01-05-2011, 07:33 PM   #17 (permalink)
NHRABill
NHRABill's Avatar
Tahoe - '95 Chevrolet Tahoe LT
90 day: 13.22 mpg (US)
SRX - '04 Cadillac SRX AWD
XL - '05 Harley Davidson Sportster XL
90 day: 49.97 mpg (US)
Alero - '02 Oldsmobile Alero GLS
Corvette - '75 Chevrolet Corvette Stingray
No need to gear them down when the small engine boost is reduced by using multiple alternators in a serpintine setup the gasses won't create much boost to begin with and will be lessesned by the load an excess can be dealt with via traditional means Blow off valve tube.
you also have to look at the type of turbo being used you can get a sealed unit where it will have more drag due to its internal oiling system as compared to a f low through like in older car models.
1,000 different ways and no one has actually done it yet and talked about it at least ...
Good topic for discussion my 1st comment is because I thought that it needs to be tied that is why I try and not draw too much attention to it untill I did it myself and then let the criticism come out.
2012 Chevrolet Traverse *active*
2002 Oldsmobile Alero GLS *active*
2002 S10 2wd p/u 139,000mi. *active*
1975 Corvette Stingray *active*
1994 Camaro Z28 Convertible 149k *Sold 2013*
1998 Blazer ZR2 189k *Sold 2012*
1995 Tahoe LT 250k *Sold 2011*
The Following User Says Thank You to NHRABill For This Useful Post:
Zerohour (01-05-2011)
