Old 04-24-2008, 02:09 PM   #31 (permalink)
ke7en
Honda Civic GX
Civic GX & Phill
I'm not sure why the Phill doesn't have more widespread availability. It probably either has to do with having a certified local person to install it or local regulations. We had to get ours approved by whatever local housing board there was here (our installer took care of that). The company said they would send out their own engineer to help with the process is the board had any questions.
As far as noise, it isn't too bad. One of the bedrooms in our house is right above the garage and you can hear it, but it is more of a quiet hum. Standing directly outside my garage with the door closed you can hear it if you listen for it, but it is not something the neighbors would notice unless you share a common wall with them.
