Good ideas! keep them coming
@ redneck
how prone is bondo to chipping? I was thinking I might add fiberglass on top of it (I need a base to mold the fiberglass to).
The floor jack and pin idea is good for getting the hitch in, but the top brackets need the back pushed up and in as the tail wants to sag away from the top edge of the car.
To all, I want a water tight seal if I can get it. If I bondo then weather strip should this keep the water out? If not what do I need to do to protect the tail from rotting, warping etc?
