Old 01-06-2011, 05:51 PM   #10 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Arragonis View Post
Originally it was just an idea but I'm taking it more seriously. I've been watching the GPH at idle which registers 0.16 after calibration. How does that compare with yours ?
That sounds about right although it may go even lower when everything is fully warmed up and depends on how many electrical accessories I am using. Are you aware of the three extra glow-plugs in the coolant? They help these engines make some heat when it's cold outside but they are a pretty big current draw until they cycle off.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
