Old 01-08-2011, 12:42 AM   #8 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I like your car choice, wagons are nice mix between people and cargo and MPG
Mod tips (links are to our wiki mod page for that mod):
1. grill block is a cheep easy first mod. Grill block partial or full - EcoModder
2. smooth wheel covers Smooth wheel covers - EcoModder
3. belly pan Belly pan - EcoModder
4. Rear wheel skirts. Rear wheel skirts - EcoModder
5. side mirror delete. Side mirrors - EcoModder
6. Tire pressure to max sidewall. Increase tire pressure to max sidewall - EcoModder
7. Scangauge ScanGauge OBD-II computer - EcoModder
The first 7 are relatively cheep and easy to do. 8- 10 are harder but sill very doable.
8. Kill switch. Engine kill switch - EcoModder
9. Kammback. Partial Kammback - EcoModder
10. roof rack removal. Roof rack - EcoModder
11 Full boat tail. Full boat tail - EcoModder
this one is harder and will take some $$$ and time commitment. I just did it and it took me a strait week of work and about $300.
Issues with lowering:
1. will prematurely wear out your half shafts. I have a brother who tests them at work, keep the angle the same. Any change will kill them 2-3x faster.
2. reduces ability to go over debris in road
3. reduces ability to drive through snow (might or might not be an issue for you, I need 6-8" in the winter)
before lowering a car I would make a air dam to the same height and see if that scrapes or if it helps. It is also a cheaper way to get the same gain. Front air dam - EcoModder
Is the car a gas or not?
Manual or not?
I hope this gives you some food for thought. I would also look through the other mods on our wiki, it will give you plenty to think about
The Following User Says Thank You to Weather Spotter For This Useful Post:
1.9SDI (01-09-2011)
