Old 01-10-2011, 08:51 PM   #17 (permalink)
darcane
darcane's Avatar
Originally Posted by Jim-Bob View Post
I do not have the torque converter clutch hooked up in that car as I eliminated the computer and went with a Quadrajet from a 1979 Chevy van. The Quadrajet is another secret with that car. The small primaries of a Q-Jet give very good throttle response due to higher velocity through the small venturi and allow the car to run at basically a high idle in most circumstances.
FYI, you can run a TCC lockup even without the computer, assuming you're still running the 200-4R or a 700R4. You can wire up a manual switch to turn it on, or buy one of the many kits out there to includ a vaccuum circuit.
I've got a 700R4 in my '68 Chevy pickup and I just wired up a toggle switch leave the switch on all the time. Since lockup is only in 4th, when it downshifts it turns it off anyways so it's not like it bogs down or anything.
Mike
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
