...if you're really into rough/off-road driving, there's also "block devices" which permanently 'lock' the alignment so that it absolutely cannot move/change unless something has been bent or broken.
...they're actually a set of square metal blocks, each with a slightly different hole offset.
...you buy/use the blocks needed to produce the alignment settings you want (or OEM specs).
...they're NOT further adjustable, but they're also NOT permanent, so if you want to change settings, just get & install the necessary different blocks.
