Originally Posted by Weather Spotter
Does the back snow build up something I can fix or will it be there unless I taper it to a point?
Slightly lengthening the sides, top and bottom with sharp edged plates extending beyond the rear face might reduce it - giving the air something to cleanly detach from (see those sharp edges in rear bumpers).
An even longer plate mounted horizontally on the bottom might work even better to keep the white stuff off the rear - and work like a stern plate.
You could trial with cardboard, then make something more permanent with clear plates so it doesn't obscure the lights.
