Old 01-11-2011, 01:07 PM   #131 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Here is a collection of under car pics.
Front part:
Middle:
Back:
Looking from the back:
What are you thoughts on the axle height, will the back belly pan act as a sail?
Old 01-11-2011, 02:22 PM   #132 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Looks like it may act as a parachute.
The open area between the axle and the gas tank/ rear floor/ not sure what it is will act as an inlet for air and snow/mud.
Looks like you need to add a piece from the axle forward.
you are really getting it done on this car :thumbs:
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 01-11-2011, 03:03 PM   #133 (permalink)
Wiki Mod
From what I can see it looks like there is not much of a gap on top of the gas tank, so most (if not all) air is flowing under the tank. If so it is lower then the axle already.
Also there is no exit for the air (some my tires but not much) so where would it go? would it not just build up a static layer or am I missing something?
I think I found a second driver so I might just get a video done today
Old 01-11-2011, 03:06 PM   #134 (permalink)
My experience with a similar belly panel, was that it does parachute.
You'll want to block the gap that is shown best in the fourth photo (in your above post).
Old 01-11-2011, 04:16 PM   #135 (permalink)
Wiki Mod
Well I took it for a test run a few min ago. Nothing fell off
I was testing two things in this run:
1. How my new belly pan worked
2. Air flow over boat tail
Comments on #1
It is still on! It moves up and down over bumps a bit (I hear the screws holding the metal parts on bump up on the exhaust).
After my test run I looked at where the snow was building up on the belly pan. I saw none on the inside that did not appear to come from the tires. The whole underside of the belly pan (ground side) was wet from the snow. The metal areas had melted and were dripping.
Side piece right behind the tires: (camera was not level)
Comments on #2
Video to come once it is up loaded.
As I started I had about 1" of snow on the top of the car. I watched this snow as it went off the back window. It was running parallel to the window and was almost touching it (might have been .5-1" off). I do end up with a very thin layer of snow attaching to the window (I think it is sticking to the window).
Snow did stick to the tail, mostly in areas that only have one layer of fiberglass (surface is a bit rough).
Side: note, other side has 3 layers of fiberglass and has no snow sticking to it.
Back:
Does the back snow build up something I can fix or will it be there unless I taper it to a point?
From trailing the car I think the underside air flow has improved. I saw less roiled air in the middle. I think that most of the roiled air was from the tires.
The Following User Says Thank You to Weather Spotter For This Useful Post:
alohaspirit (01-11-2011)
Old 01-11-2011, 04:35 PM   #136 (permalink)
Wiki Mod
Here is the video:
I had a cross wind (from left to right)
Here is the first for compare:
Fire away on the comments
Old 01-11-2011, 04:55 PM   #137 (permalink)
What would be interesting would be to see the video from a stationary location with the Matrix and the chaser car passing a block or so away from each other for comparison.
Old 01-11-2011, 05:31 PM   #138 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
great stuff
this is more entertaining than Tron
Past Present Future?
Old 01-11-2011, 06:31 PM   #139 (permalink)
Wiki Mod
That is not a bad idea, I would need a similar car to make a fair comparison. I can tell that the wake is smaller then pre tail. On most cars I see the wake of spinning and vortex snow is the same or taller then the car. It is wider then the car as well. On mine it is as tall as the tail (ending height) and only slightly wider then the tail is (ending width).
From trailing I can also see that it keeps this shape for a time then dissipates in about 1/3- 1/2 the normal length.
If I were to fix things more I would try to do a mini boat tail behind each tire. This would get in the way of snow and road debris so I am not planning on doing it.
I might work on the front wheel wells to reduce the gap.
One issue I have with the tail is that the foam pieces somewhere (I think in the front) are rubbing and making the nasty foam noise. What can I do to fix it? The noise is just when I go over bumps but small ones do it to so it is doing it about 90% of the time. It is not very loud but it is grating. I can live with it but others can not.
I was thinking:
Fiberglass it (not a fan but I could do, I would have to buy more stuff and the smell)
paint (might not get the surfaces that are rubbing, it could be edge on edge)
noise reduction insulation (cost $$$$)
Other ideas?
Old 01-11-2011, 07:43 PM   #140 (permalink)
Silicone spray.
Just don't get it where you'll be modifying or painting later.
BOAT TAIL Drag Reduction Estimates aerohead Aerodynamics 12 01-30-2016 04:08 PM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 9 01-19-2014 09:59 AM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph MetroMPG Aerodynamics 500 05-10-2012 10:30 PM
collapsible curved folding 10mm coroplast boat tail miket Aerodynamics 5 08-12-2010 01:58 PM
Subaru Outback Prototype Boat Tail Test Results brucey Aerodynamics 10 10-02-2009 05:03 PM
