Old 01-12-2011, 01:00 PM   #18 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
There is a vacuum pump in the area shown in the photo too. It may be just under that vacuum pump if my memory serves me correctly. I will try to get a photo this evening. I have heard that some Canadian drivers change the settings in VAG-COM to keep those glow plugs on longer to get heat into the cabin more quickly.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
