Old 01-12-2011, 07:27 PM   #145 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
aerohead, nice summery and comments.
I might make the end panels per the suggestions, how long? Can I make it come to a point?
I might do some tuft testing when it warms up. Most modding has come to a frozen stop
As for the sides, I need to do some work on the transition from car to tail. Right now I have it changes angles twice, at the car and at the top end of the window. The angles might need a bit of work but that is fill in and finish stuff, on hold till temps are 45-50F (mid march).
You are right in that I decided for the squared off shape due to the labor needed. To be totally honest I only sketched it out, most of the design came during building phase.
I may do a mid section belly pan, But I need more material I am out of any good sized colorplast or sheet metal. It is also easier to get under the car without winter gear on.
If I do 3 season mods they will only be on for 6-7 months a year
any tips on reducing Styrofoam squeak?
