Old 01-13-2011, 03:50 PM   #20 (permalink)
Jim-Bob
Junkyard Engineer
Jim-Bob's Avatar
Super-Metro! - '92 Geo Metro Base
$250 Pizza Delivery Car - '91 Geo Metro Base
90 day: 43.75 mpg (US)
Fronty the wonder truck - '98 Nissan Frontier XE
If you're doing mostly city driving I'd go with a Prius. HSD is quite a bit superior to IMA in the city. You can find the first gens for a few thousand dollars around here. An Insight can probably keep up with the Prius MPG wise, but it'll be more work.
Doesn't the Prius allow for partial electric-only drive? If so it makes sense then. That would also allow me to do a plug in conversion for a little more electric-only range and maybe even add some solar cells to the roof for charging during the day.
I always found the Insight I to be sort of cool for being a no-compromise solution to fuel efficiency. If the Prius I makes more sense though I will start shopping for one of those instead.
No green technology will ever make a substantive environmental impact until it is economically viable for most people to use it. This must be from a reduction in net cost of the new technology, not an increase in the cost of the old technology through taxation
(Note: the car sees 100% city driving and is EPA rated at 37 mpg city)
