Old 01-14-2011, 09:33 AM   #22 (permalink)
JasonG
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Relocating the extinguishers is a must.
He cant wrap the fairing back to the motor or it will push him into funny car class.
The winglets on the front need to be extended so the vertical fins line up with and are closer to the pizza cutters.
The rear fender needs to go to the edge of the tires and be tilted out at an angle.
On the red rail notice the horizontal piece on the rear fender/ deflector. It provides support and downforce due to the angle.
Depending on your class, you may not be able to remove the wing. Just try leveling it a bit.
A partial Kammback would be good, just check the regs to stay clear of the chute.
Fairing behind the drivers helmet will provide little aero benefit but will cause less head buffetting.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
