Old 01-14-2011, 09:43 AM   #26 (permalink)
Bennett_Racing
Novice but learning!
Originally Posted by nitro-nige View Post
I second the move the fire extinguisher.
Put a full hood on it and enclose as much of the engine at possible. Hiding the Mag from the air might be hard unless you can find a way to change the drive.
It's a topolino body? Could you put rear guards on it, something teardrop shaped?
def going to look at moving bottles, makes sense
as a note to all,
there is no wind/air inside the cockpit, can drive at 220mph with visor open if you wanted too
yes its a topolino, we added the arches
can you explain rear guards? any photos?
thanks
