Originally Posted by COMP
what about water/meth. mix ??
Meth-Alcohol? Doesn't it cost more than the regular stuff?
I was reading another article on Mother Earth News that at 202 proof, you can burn pure alcohol. They've even got a variety of homemade stills (tower) for the backyard. Worth checking out.
In either case, making your own with newsprint or wood chips would be cheap enough (rainwater from the eaves), and Mother Earth showed which are the best sources for the starter yeast and making your own yeast culture. Just run a search for the keywords, and then search for the expert named in the article.
If you really want to make it for almost zero cost, build a small solar water heater from a good sized dual-pane window.
http://www.motherearthnews.com/Moder...rd-Stills.aspx
http://www.motherearthnews.com/Do-It...-Cookbook.aspx
http://www.motherearthnews.com/Moder...-Solution.aspx
http://www.motherearthnews.com/Green...-And-Cons.aspx
One Search I did:
http://www.motherearthnews.com/searc...rch=distillery
Wood Alcohol:
http://journeytoforever.org/biofuel_...d_alcohol.html
Hope that helps.
