My Jetta TDI pulses nicely (good pull making for relatively quick acceleration) and then glides well (probably because if the weight!). But re-starting when turning the steering wheel is scary because it "over-corrects" and I end up suddenly going several degrees further in the direction I'm turning once the power steering kicks in... so I don't glide with the engine off.
