Originally Posted by dremd
I thought I had posted in this thread before ????
I did see SOME FE gains with Water injection on the Supra. My setup was super cheap, proportional to the Fuel flow, and worked well.
In a Nut shell Fuel pump, Fuel pressure Regulator and 1 injector sized to be ~10% of the Sum of all of your FUEL injectors. I had 6 550 CC/Min's and 1 370 CC/Min injector for water. I ten taped the "7th injector" to one of the Batch lines, plumed it up and it worked well.
If anyone is interested, let me know and I'll explain in much more detail.
A buddy just won an AEM Water/ methanol Injection kit, I'll let you guys know how it works when we get it on his car.
I would like to hear more about this setup. I was thinking about doing the exact same thing until someone pointed out that that fuel injectors don't last too long with water running through. Do you have pics? thanks
